Fusion brake issue
Richmond
VA
2011 Fusion
I'm hoping someone can offer some help here. I have a 2011 Fusion with a "no pedal" issue. Car had a caliper fail. I replaced all pads, rotors, calipers (yes they are installed correctly with the bleeder on the top) and hoses. This is when the no pedal issue surfaced. Performed brake bleed with parking brake on in order of RR, RF, LR then LF. Did ABS bleed procedure through a scan tool. Nothing. Replaced master cylinder. Bench bled, then followed the bleed procedure again. Nothing. Replaced ABS pump and had it reprogrammed for the car. Performed the bleed procedure again. Still nothing. It seems like I get some pressure to the LF and RR wheels and none to the LR and RF. Im at a loss. Has any one else run into this???
Sent from my SM-G973U using Tapatalk
tomang07
D
ME
Ford
This forum seems pretty dead.
Did you ever figure it out?
I'm about to do a full brake job on mine.... hopefully it doesn't have any issues.
Sent from my SM-G960U using Tapatalk
