- Messages
- 3
- Likes
- 1
- City
- Southampton
- State
- Non-US
- Country
- United Kingdom
- What I Drive
- 2014 1.0 ecoboost titanium X 125ps
Hi,
need some diagnostic gods to help me out.
Car: I have a 64 plate Ford fiesta 1.0 ecoboost titanium. 125bhp version. 68k miles. 3 door.
issue: intermittent “service now” or engine management light with rough idle and lack of power.
OBD code: P0237 “turbocharger/supercharger boost sensor A circuit low”
So this issues only occur when starting it. When it first did it about 6 months ago it went into limp home mode on start up with a rough idle and lack of power. Had to take it to a garage who replaced a MAP sensor. It seemed to work for about 3-4 months.
unfortunately, it happened again. Similar rough idle, and stuttering on trying to rev it. Occasionally cutting out completely. The “service now” light came on. However, I turned the engine off and on a few times and it came back to life, with the light going off. It’s happened a few more times too, sometimes if I just rev it for a bit it seems to sort itself out and becomes absolutely normal again. Sometimes I have to restart it. Occasionally the engine management light will come on too, but this goes once I do the restart.
The fault code is always the one above. I changed the MAP sensor and what I thought was the boost sensor. (See photo below) But this did not work. I’ve done a full service with oil, filter, air filter, spark plugs, pollen filter, full coolant change, but with no joy. I took it to the local garage again, they couldn’t work it out either and said bring it back once it does it again and charged me £90. 🤣
Just to clarify, inbetween these episodes the car drives perfectly. Lots of power, normal idle. In the normal temperature range and coolant level isn’t going down.
I will attach a photo of the fault code. And the sensors I replaced. I’ll also add a video link. Any help appreciated.
https://youtube.com/shorts/En0c-1XnX-Q?si=zPVrpK2qmM1dSokG
