    Welcome to the #1 Fiesta ST Forum and Fiesta ST community dedicated to Fiesta ST owners and enthusiasts. Register for an account, it's free and it's easy, so don't hesitate to join the Fiesta ST Forum today!
Turbo Blanket
Location
Las Vegas
Does anyone on here use one or used one in the past? What's your experience with them or your respectable and intelligent opinion on them?
Here in Vegas the summers are pretty hot so anything to reduce underhood temps would seem to help so Im just curious if this is a viable option as this is my first turbo car I have owned.
rodmoe
5000 Post Club
Location
wausau
Not sure about the stock turbo but the DEI turbo blanket fit the GTX turbo just fine but getting it on with turbo installed was a bit of a challenge for someone with meaty hands ...
Linky
TheStig
Senior Member
Location
Phoenix
Not really necessary for us on stock turbo's
Im in Phoenix so today it was 112 for example, it gets hot under the hood but nothing too crazy. As long as you arent tracking it in 110+ degrees it will never be a problem.
redsilvy
Location
Las Vegas
Just curious and I'm sure others wonder too. Yeah I don't plan on any tracking until probably October. Haha Found that out at the drag strip on Friday.
Time to modify the grille and trim the bumper for a bigger opening for the FMIC.
Sourskittle
4000 Post Club
Location
Lakeland
I've been wanting to try one on my setup while heat wrapping the manifold at the sametime. If I convert to an external wastegate, I'll def be doing both.
OffTheWall503
1000 Post Club
Location
Memphis, TN
Linky
I wonder if this insulation kit would be beneficial on stock turbos.
https://www.designengineering.com/c...ponent-specific-products/turbo-insulation-kit
Or this
https://www.amazon.com/Thermo-Tec-1...=1469301710&sr=1-20&keywords=turbo+insulation
Sorry to bump an old thread, but I'm curious if anyone has used these on the stock turbo.
OffTheWall503
1000 Post Club
Location
Memphis, TN
#11
Will it fit with the stock heatshield on? I'm curious about these and was wondering if they would fit.
Siestarider
Senior Member
Location
Stuart
#12
My experience is all negative. Very difficult to install with manifolds wrapped. I worry about fires too. Hard to be sure bulky blanket is not touching the wrong place.
Default for me is wrap dowpipe and manifolds, put heat shield back on. I have a hard time believing wrapping turbine housing alone makes a difference, but wrapping up and downstream is easy and might help.
Location
Dublin, OH
#14
Good bit of info from 'Engineering Explained' on YouTube:
[video=youtube;FrFeaNGDnOk]https://www.youtube.com/watch?v=FrFeaNGDnOk[/video]
I watched that yesterday and like most EE videos, it was very informative. That said, I worry about trapping and retaining all that heat in the turbo. It is good practice not to turn the motor of immediately after running hard so the turbo can keep getting oil flow to cool the bearings down a bit. I have heard forever that failing to do this could coke up the bearings as the oil is way overheated and turns to carbon. This same reasoning is why turbo timers exist--to continue oil flow for a short time after the motor shuts down. So I fear that trapping all that heat might have a negative affect.
shouldbeasy
1000 Post Club
Location
Calgary, AB, Canada
#15
They specifically said there was no difference in coolant or oil temperature but the exhaust temperature rose dramatically.
The heat is leaving via the exhaust as opposed to being contained to the engine bay.
Quisp
1000 Post Club
Location
Davenport
#16
Turbo timers we're great for non water cooled turbos of the 70's and 80's.
TyphoonFiST
9000 Post Club
Location
Rich-fizzield
#17
This is only for non water-cooled turbos. They now make almost every turbo water cooled due to the old coking of the turbo when doing a hot run to the grocery store. It's a convenience thing now days....the Manufacturer/Car maker doesnt want to put any type of unnecessary steps for the consumer to inhibit them from buying a car due to scaring them with the un-watercooled Turbo and more steps to follow after shutdown. My Typhoon I have has a non water-cooled turbo now due to me disconnecting the line and I run a Turbo timer now set for 3 mins after shutdown of the engine....the Truck still Runs and automatically shuts down aftrer the timer has been exceeded and I'm drinking an ice cold beer trying to wipe the grin off my face after a 10lb. Boost launch In the street!
Sent from my SM-N950U1 using Tapatalk
M-Sport fan
9000 Post Club
Location
Princeton, N.J.
#18
Today's oils, especially the synthetics, are also a lot less prone to the volatility, and shearing of their base stocks (which promotes/enables the 'coking'), and their viscosity index improvers due to extreme heat, since they use MUCH better component base stocks and VI improvers (IF they use any VIIs at all, some of the premium synthetics, like MPT 30K do not) than what was available in the 70s to late 90s.
TyphoonFiST
9000 Post Club
Location
Rich-fizzield
#19
Heck to the yeah!
shouldbeasy
1000 Post Club
Location
Calgary, AB, Canada
#20
Ford Community Posts
