Swapping 12v outlet for and actual cigar lighter (Mk7,5 Fiesta)
Khobshe
Seattle
WA
2015 Fiesta Titanium
Has anyone swapped out the 12V outlet in the front out for an actual cigar lighter with an element in a Mk 7,5? I looked around and haven't seen any posts about this. I'm a smoker and even though I don't smoke in my car I always prefer having a cigar lighter in my car in case I forget my lighter. From what I've seen the cigar lighter was part of the optional smoker package, which of course mine doesn't have. I know you cant just put an element in the 12v accessory port since they aren't rated for the heat but does anyone know if its just a drop in swap or is more to it like changing fuses or otherwise? I might have a look in the local breakers yards to see if there's a Fiesta with it fitted to nick it
I've found some phone battery chargers as well as some devices using 12 cigarette lighter - heat up hotter than leaving the element from a typical cigar lighter in too long in a winters day only to burn your hand from doing just that...
Long story? No? Ok, just remember to use some kind of backing plate - the plastic hole housing will get soft - Tractors Supply (TSC) did sell washers that would fit the screw-in type of cigar lighter diameter to act like a "gasket" and provide/act like a heat sink - but it requires surface area to dissipate that heat.
Hooking up the Electrical for the heating element is the only issue I see.​
K
Khobshe
Seattle
WA
Thanks for the reply, the stock 12v power outlet is not rated for the heat of a cigar lighter so its not as simple as just getting the element and popping it in.
So far I've found the 3 part numbers for what seems to be everything needed for the swap (nobody wants that ashtray haha):
Element: CV6Z15052A
Socket: CV6Z15055A (this *should* be the correct one the stock one is BK2Z19N236A)
Ring: F8RZ15K040CA (this is for mounting and has a light to show when the element is engaged, these have been around for 20+ years)
I also called a Ford dealership to ask about the feasibility of the swap and if there was any wiring/fusing differences and they didn't seem to find any, but I'll pick up a wiring diagram to be sure. So now all that's left is to get the parts but I'll see if I can't find one at a breakers yard to see it in situe and if I can get it for less. Once again if anyone has done this swap let me know!
I have only added a 12V lighter socket, not for cigar - but as a means to offer rear passengers a 12V charge port.
Which is how I became aware of some phone chargers - being 3.0 amps or more - have generated a lot of heat in dropping the wattage for that amperage (linearly not switching types) from 12V to less than 5V (even at 6V - 6 X 3 amps is 18 watts - some brake light bulbs toast sockets with less) so they can consume easily a 5 amp draw or roughly 30 watts in dissipation, but the 110V 300W inverters take easily 10~15 amps - which is certainly even more than the rating in a heater element in a typical Cigar lighter.
